ronw
Having trouble finding a balancer. I got one from summit (Sum-163273) When compared to the original, the TDC cut was on the wrong side(drivers side). On talking to the tech at summit we ordered the Mopar Direction balancer (DCC-4452816). The TDC cut is the same as Summit drivers side). The 68 340's timing indicator is on the passenger side because of the water pump neck on the drivers side. One solution I think is to remark the balancer at TDC. I'm asking if there is a correct Harmonic balancer? I'm sure someone has had this problem. Ron
