furydan
not so junior member
Would a 66 273 engine use the same harmonic balancer as a 69 318?
Yep.Both are neutrally balanced,just check that the timing marks are the same
Yep.
Later externally balanced engines will have a counter weighted balancer and will not work. The balancer from any neutral balance LA should work just fine as far as balance goes. The timing marks may be different , but that problem can be overcome with a little creativity.
