Harness mounts....
inkjunkie
I know the shoulder harness's are just wrapped around the cross bar.....but what is done with the lap mounts? Just use the oe mount?
I attached mine on the same bolts as the factory belts on the floor between the factory stuff and the floor.
Worked out fine.
Yes, use the OE mounts. For the submarine belt I just drilled a hole in the floor and put a backing plate on the under side to give it extra strength so it can't pull through.
