too bad the "muscle car" died as Ma Mopar began to replace the 340 with the 360. I read an article where Larry Sheppard mentions some interested things that would have made the 360 revered as the 340.
It would come down to "difference in friction". There's an "App" for that, well...not an app but a formula!!
The engineering of a bearings Babbitt lining is usually completed during the design of the machine. In selecting the proper type of Babbitt for a particular job there are a number of factors to take into consideration, the most important of which are as follows:
1.Surface speed of the shaft
2.Load that the bearing is required to carry
There is no doubt that if a bearing is to be highly loaded in relation to its size, a high tin alloy is desirable; whereas for much slower speed work and less heavily loaded bearings, a lead-Based Babbitt may be employed, and is far more economical.
1. Surface speed of the shaft: (The number of feet traveled per minute by the shaft circumferentially.)
Formula: (Pi x D x RPM) / 12 = S
Example: Determine the surface of a 2 inch diameter shaft going 1,400 revolutions per minute (RPM)
(Pi x D x RPM) / 12 = (3.1416 x 2 x 1,400) / 12 = 733.04 Ft/min
Where: Pi = 3.1416, D = Diameter of shaft, S = Surface speed of the shaft
2. Load bearing is required to carry: (the weight which is being exerted through the combined weights of the shaft and any other direct weights on the shaft and measured in pounds per square inch.)
Formula: W / (I.D x L.O.B.) = L
Example: Determine the load on a bearing of a 2 inch I.D bearing, 5 inches long and carrying a weight of 3,100 lbs
W / (I.D x L.O.B.) = 3,100 / (2 x 5) = 310 Lbs/sq.in
Where: W = Total weight carried by bearing, I.D = Inside diameter of bearing, L.O.B = Length of Bearing, L = Load bearing required to carry
You can actually calculate the amount of friction gained or lost simply by knowing the speed of the shaft, weight carried by the bearing,ID of the bearing, etc, etc.
I doubt you could measure it on a Dyno because threre are too many variables, it's like building two engines exactly alike, and I mean exactly!! The chances of them both having exactly the same horsepower is next to none, even though they were built the same!!
Treblig
Its mostly brought up in my opinion because it falls into the old wifes tells category. And another thing to consider, is that a "narrow" rear main bearing can be installed in the 360, reducing a SMALL amount of bearing surface area. Its in the engine bible. ALSO, where the 360 has larger main journals, it has a SHORTER and LIGHTER piston than the 340, so that probally nullifies ANY bearing friction difference anyway.
If this is really keeping you up at night, the solution is simple. Bolt the appropriate cranks into the appropriate blocks, bolt a belt adapter to the crank flanges and an encoder wheel to the crank snout, and power the cranks with a supply of lube by an electric motor; no rods, no pistons, no cam drive.
Pick an RPM to run them at and see how much current it takes to spin each at the given RPM. The difference in current can then be easily converted to the hp gain/loss for a given crank.
As I said, too many variables to measure in an applied example, but the difference in drag: quite simple.
If you have these kinds of questions, get a Shigley's and start going to college. You'll do well in life.
