I just replaced the front and rear windows in my 71 Demon. I used the DMT clips and I got them to work but it was a Bear! Make sure the front bottom middle 5 are the longer ones. I ended up using a 1-1/2”x3/4”x 6” piece of plastic l had from a different project and I found that if you held it on the outside edge of the trim and hit it with a rubber hammer in a down and it direction, it would open up the clip just enough to slid the trim down and into place. I know it sounds weird but it worked very well.Hi Folks
Just got the glass installed in my 1971 Demon. I installed brand new DMT clip kits for both front and rear prior to installation. Come to install the stainless trim and the clips don't work worth a crap. Looking at the originals, there is a slight difference in their shape. Does anyone have any tips?
The originals did not have 2 different sizes.....They were all the shorter ones. These DMT clips are the same height, but won't catch.
Clips cannot be removed with the rubber gaskets installed.......HELP!
Thanks FABO
