When you can buy a complete EQ head for less the $500 why mess around with anything else for the street. There's plenty to read about these heads on the net. Seem like an excellent bang for the buck if you're planning to go modern. Check these out.
http://cgi.ebay.com/ebaymotors/NEW-EQ-MONSTER-MAGNUMS-318-360-CYLINDER-HEADS_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem160313976767QQitemZ160313976767QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
making me think of sending my x's over to shady dell.....Im not sure.But as far as why mess with 40 year old heads when you can have new aluminum heads.My buddy did a home port job on his J heads for his stroker build and got 270 CFM,fully preped and set up for under a grand.My .02
The Magnums are better at certain things... they flow fast, but not record numbers... On getting 270 from a set of Xs with home porting, the bench wasnt right or he's tellign stories. Not without welding or epoxying can that be done. Magnums are a very good mild to medium performance head, expecially in the EQ versions that take LA manifolding and do not have cracking issues. The issue comes tryign to get bigger cams into a magnum headed engine. They get expensive to put a real cam in. So it becomes cheaper to use the LA version aftermarket aluminums and port as needed.
