According to my casting number this head was used 1964 thru 1967 on 361,383,413,and 426. Has 2.08 Int & 1.60 Exh. Can anyone tell me if I can use them on a stock 440 .030 over? And use all factory bolt ons. Thanks Ron
What makes you think you can't? Your own research shows them to work on lot's of "B" and "RB" that were progenitors of your 440.
They will bolt down, the big question is what your compression ratio will work out to be, they are a small chamber head. Need information on what pistons, how far down in the hole, final chamber volume, and gasket used.
