head changes over the years
gtsport
Member
Dayton, Ohio
Folks, just bought a 65 Barracuda \6 automatic car. the engine is in great shape except for having the far back exhaust manifold stud broken off. using a screwdriver, I feel a bit of the stud still sticking out. I plan on pulling the intake/exhaust manifolds to see if I can be lucky enough to soak it and unscrew it. my luck says it won't work. so the question is: how much was the head changed over the years? if I have to pull it, would I be as well off to find a later head with the hardened valve seats? or did Chrysler ever change to hardened on the \6? were passages changed any to make better or poorer breathing? when did those engines go to hydraulic lifters? I remember back in about 65 adjusting the valves on my 62 Dart. will a 2 bbl or a small 4 bbl carb wake this engine a little without a cam change? headers? choices of 6 into 1 or 6 into 2? I'm calling on experience of you who have been here before, the most bang for the least bucks, or just fix the stud and let well enough be? thanks in advance....
The slant head got hardened valve seats in '72, lost the drool tubes in '75, picked up AIR injection in '76, and hydraulic lifters around '81-'82. There wasn't enough difference in port shape or chamber size to say any one year is THE one to have. I would fix the broken stud for now and keep an eye out for a '72 or newer head. My '66 Valiant's #6 exhaust valve is refusing to keep proper adjustment due to valve recession after only 25000 miles of unleaded gas. I have a '73 engine waiting to go in as soon as I get off my butt and do it.
see if i can help a little..
when we picked up the '75 dart, the /6 was a little leaky and had a carb problem. we pulled the motor and and did a complete rebuild: new rings cam with .252 duration and a 2bble manifold and carb. seemed to wake it up a little :) we broke the rear manifold bold off and took it to the machine shop and had it tanked and shaved a little just for piece of mind. he threw in a new stud for free. it has solid lifters and had to adjust the valves (i do it while its running) not sure about the seats tho.
we did all this for piece of mind so we knew what we had before we started to drive it and not have to worry about the engine, and we didnt spend alot of money on the rebuild doing it our self. just recommend throwing a remflex gasket in the intake exhaust manifold.
glad to see you would like to fix the slant...especially when everyone is going the easy way and throwing a 318 in it. everyone can have a v8 i prefer the leaning tower of power :) i guess just because its what most people wouldn't do.
Slant-6 heads with air injection ports were first released in '72. There were heads with and without the air injection ports starting in that year. Remember the California-emission cars got air injection (and a very primitive, non-valved EGR system) in '72.
1981. And while the '81-up head is different, it is interchangeable with earlier heads regardless of whether you're running solid or hydro lifters.
True, though the '67-up heads have the better combustion chamber shape (revised that year for more complete combustion) and the pre-'75 heads w/spark plug tubes mean a much wider range of spark plug options—including the NGK ZFR5N, which has a double-extended electrode set that moves the spark point closer to the middle of the combustion chamber and away from a quenchout zone. They are not gimmicky "magic" plugs, just a good design variant of a standard plug, originally designed for tough-to-light engines (desmogged AMC 232/258, Chrysler TBI 318s in '81-'83 Imperials), 'cause the mixture is much less variable in the middle of the chamber than at the edges, and these long-electrode plugs give more consistent light-off of the cylinder under borderline-combustibility conditions. The same extra-long electrode set is used in many late Mopar applications (3.5 V6, 4.0 I6, etc.), and they work very well in slant-6s. Remember to remove the metal ring washer from the spark plug before installing it in a '63-'74 head.
Yup. If you take your time and think ahead, it shouldn't be much of an ordeal. If you get impatient and do something like break off an "Easy Out" (hah!), you're in for a much harder task. If you wind up having to drill the stud hole oversize, you can get a stud with bigger threads on one end and smaller on the other. Dorman #675-097. It has 3/8"-16 threads on the head side, and the stock 5/16"-24 threads on the manifold side. Overall length is a little shorter than the 675-092 standard replacement stud, but that's of no consequence. That's what I wound up successfully using at the end of a long comedy of ignorant errors and dumb mistakes* a long time ago on my '65. All you have to do is overdrill the hole straight and true. Head on engine: Not a problem. Manifold on head: Not a chance.
Use Loctite (not RTV or teflon tape) on the head-side threads, which means you need to clean the coolant and tapping oil out of the overdrilled head hole using something (alcohol or brake cleaner, e.g.) that won't leave a residue. The head threads are 7/16" deep on the 675-097, while the original-type 675-092 has 9/16" of head threads; if you're careful and mark your tap accurately with a loop of masking tape, you can make (leave) a ledge at the "bottom" of the overdrilled head hole to bolster stud seating and sealing.
*-involving a hammer drill, "EZ-out", jigsaw, tap extractor, JB-Weld, Plexiglas heater, and assorted other inappropriate tools and supplies
Meh. I wouldn't turn down a '67-'71 head. The factory induction hardening is not very deep; it's standard practice to install hard exhaust valve seat rings during a good head buildup, anyhow.
Handy chart listing slant-6 hard part variants (most, but not all) is here.
And welcome back, Grumpus.
