Head gasket question - 318 build
Patrick
Olney, MD
I've been waiting for 1.5 months so far for my MOPAR shim gaskets to come in from Jegs and i'm still getting the dreaded "it'll be another 2 weeks" story - apparently there's a major delay from the manufacturer. I was planning on using these thinner gaskets to bump up compression on my stock 318 headed build... but summer is flying by and i want to drive the conv before xmas! :angry3:
I installed a 340 cam in my 318 and refreshed my stock 318 heads (early 70's vintage) by lapping the valves and installing new (cam matched) springs and new keepers/locks.
Here's my question: can i use the stock head gaskets without fear of lost compression or should i just wait for the thinner ones?
You Could Get The Heads Shaved Down A Bit And Use A Stock Gasket. I Would Think Any Machine Shop Has A Re-surfacer Machine!
I could do that but it's all ready to go... and my eventual plan is to redo my 302's and put those on the 318. So i want to use this setup temporarily and just make sure it's not going to be a dog. Believe the 340 cam is really not that radical but what i don't know is how different stock compression ratios where between the 318 and the 340...
Thanks for the feedback!
Try looking around for a mr gasket 1121 head gasket set,these are .028 when compressed,they have a 4.140 bore but it is still smaller than the felpro @ 4.180,also the smaller quench are makes the bore size pretty insignificant,only around .02 less compression.
