Head gaskets for Aluminum Heads
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Generally speaking which brand of head gasket is best (in your opinion) for mating aluminum heads to an iron block?
cometic is a great gasket, edelbrock "makes" their own units that they specifically recommend for alum heads as well. don't discount some plain ol' fel-pro perma torques. i've used all three and had great success with all of them. just depends on budget and application.
something to keep in mind: some gaskets require a specific machined finish on the deck and head surfaces, with out that you'll have poor performance, longevity or outright failures.
Do you know which one(s) require special head/block machining. If not, maybe someone will chime in with the answer
many MLS ones have specific criteria, generally smoother than a "standard" finish. most composite are fairly forgiving.
i know that's pretty vague, but it's best to check the mfgr's specs before committing.
Ive used just about every kind of gasket on every head block combo. Copper, composite, mls, steel shim, etc. and never had one that worked better or worse than any other. Cometic says their gasket needs a specific RA on the deck surface but I know guys that don’t bother and just run em on big boost LS stuff with no problems. Pick a gasket from whatever brand you like, and gets the compression where you want it and send it!
The white car in the avatar uses an ordinary composition gasket with an aluminum head/iron block.
But it does have 27 head bolts. And about 6.5 to 1 comp ratio.
The 1008 has a wire ring for higher compression.
My block will likely be close to a bore of 4 inches or slightly less. Wondering if the 1008’s ring at 4.180 would be too large or perhaps Cometic’s 5622 4.080 or Cometic’s 5916 at 4.040 (recommended for iron block/aluminum head application)would be better choices All 3 have the crush value of .040 as recommended by Jim at Racer Brown
AND, it doesn't hurt to retorque them after a few heat cycles. I know that they say it's not necessary, but I always find 3-6 that need it.
Mr gasket has a line of steel multi-layer gaskets I would be willing to try. I use cosmetic 4.080 with over 195 cranking compression and spraying it never a failure On my 345.
If I were you, I'd CALL Cometic and tell them what you have, what you are doing and what you want. They are the experts.
I would stay away from the Mr Gasket product. The set I had installed leaked onto the floor as I added water for initial fire up. To say I was pissed is an understatement. Changed over to 1008 Fel-Pro, not one drop. I have Cometics on two other engines that have aluminum heads, worked as designed.
I called them today; talked with very knowledgeable tech rep who did ask quite a few questions. The final tally was to build custom head, intake and exhaust gaskets based on what I have, my goals and what my machine shop recommended based on my parts.
This engine is destined for my 47 Dodge
When the composite head gaskets on Neons were blowing out, the MLS solved those problems. The procedure involved covering the gasket with a pink tacky spray stuff from Mopar. Do the modern MLS gaskets require the pink spray??
