superdart360
Id like to see the push rod hole to push rod clearence.
Early heads arent opened up for the amount of travel/angularity that the roller cam puts the push rod at.
Its not bad with a hyd roller because of the cup height , but with a solid roller ...u will need to grind the push rods holes larger.
You are correct the stock pushrod holes where way to small. This motor is a hyd roller and when we originally placed the heads on the block the pushrods would bind.
We bored them out to 5/8 inch. We have not had any clearance problems.
