Header bolts for Trick Flow heads
royalbull73
Active Member
San Antonio, Texas
Greetings;
My questions are, should I use stainless steel bolts to attach my Doug's headers to my aluminum Trick Flow heads or should I just use grade 8's? Also, should I use anti-seize or Loctite on the bolts?
Thanks in advance.
