68gts340
trying to help out a neighbor kid, here s the problem ; just removed a set of hooker comps, 1 5/8 tube, put in hooker super comps, 1 3/4 tubes, ....now it is running rich, today i went through the primary side , new power valve, checked all the passages , and found nothing. it s runing a 3310, 750 cfm vac secondarys, the car has been sitting about three years, last time i helped him jet the carb and the plugs were nice tan , a little on the dark side ,but not bad, the motor was fresh then so we decided to run it like that for breakin,,,,, now the plugs are black , but dry.........my question is this ..can the tube size affect jetting that much? or should i dig into the carb some more ? i tried the idle air adj and it will stall out the motor closing them, but it runs best at about 3/4 turns open.. i know it needs jetting down, just wonder if i am missing something ? any thoughts on this?
part two;.. next step he wants to try an 850 double pumper, i need a starting point for the jetting. it is a used carb and the jetting isnt as new, also this has a rear power valve, do you recomend square jetting it? i dont have a lot of time with this car so any help will sure be appreciated... thanks
one last thought... it a good chance it has last years fuel in it ..
