headlights are dimmed and turned signals won't blink
DartThis74
Houston,Tx
Hey everyone, I have a slant six '74 Dart Sport and for awhile now I have noticed that when I am at a red light my blinkers either wont blink when I turn them on or they blink extremely slow for instance 1 blink for every 2-3 seconds. But when I hit the accelerator the blinking picks up to normal as if the voltage gets stronger since the rpm are higher. The headlights I've noticed also tend to be dimmer and same thing when I accelerate they get even brighter.
Before I've noticed all of this stuff happening. My car sorta crashed on me a few months ago. After much trouble shooting, we found that the ecu was the cause for my car stalling multiple times while driving which resulted in the car never firing at one point. The alternator was replaced along with the ecu, as far as its Amp output I do not know.
One more thing. While I start my car up, the ampmeter will shoot across the gauge to the positive side when I hit the accelerator and then drop back down to a little into the negative side. But after a few minutes of driving it settles in the middle two marks like normal. Like I said above, before my car crashed on me none of these issues happened, but now after replacing components my car finally runs BUT now have these small issues. I appreciate any help you have. Thank you
Aaron
You could have a number of troubles bundled together.
First, how's the idle speed? Can you crank it up a little? I like to run mine "a little high" just not high enough to cause annoying creep in gear
Second, suspect the alternator. You might have one or two open diodes, which will turn, say, a 50a alternator into about a 30A alternator, with much less efficiency, and it could have other troubles.
Measure your running chargiing voltage, at the battery, while running the engine at an RPM to simulate "low to medium cruise."
How big/ heavy/ good is the battery? If the alternator dies down at low idle, it surely doesn't help if you have a low end, old battery that's on it's last.
Also on the list, which pops up here every day, is the condition of the bulkhead connector on these old girls. This is the huge connector on the firewall where all wiring feeds through from the engine bay to the interior. These deteriorate, the connections become hot, burned, corroded, etc.
And, there could very well be other issues--rusted, corroded, loose fuse box terminals, connectors at various points including the ammeter, the ignition switch, the switch itself, etc, etc.
Your ammeter action is "normal" giving your situation. What is happening, the alternator is "not keeping up" at a low idle, the battery is providing power and discharging, and the system voltage is going very low. Then, when you rev the engine, it charges for a short time until it once again gets the battery normalised.
Now PLEASE don't go out and start throwing money and parts at the problem.
Follow along with other comments, make tests, and make the most logical choice.
You might not find it in a day or even a week, but, hey, I'll bet it's been going on already, right?
By the way, those of us old enough to remember riding in cars/ trucks made in the '50's think this was normal operation. Just wait until you try out "vacuum wipers."
I appreciate your suggestions. When I get time to track down issues and eliminate some things I'll give more feedback as to what I am encountering. I'm not to knowledgeable on the electrical system of this car, so thought I could find someone on here that is haha. thanks
