Headliner help
sweetlea
Member
saskatchewan, Canada
I have a 1969 Barracuda Fastback.
I'm having the headliner installed in June and need to order parts for him.
I bought the car Dec 2023. The man rebuilding it passed away. His wife gave me everything she could find, but I'm sure lots is missing.
Does anyone know what the headliner poles/bow look like?
Attached picture of what I think I need to order
That looks like them but I have a Dart not a Barracuda. I also know they go in in a certain order but your headliner guy should be able to figure it out.
Ok, so here's what you will need.
Proper bows as you have shown.
Cups.
See below.
Headliner bow tension springs.
See below.
Also, do you have the interior roof rail trim? Its usually same color as the headliner.
This, along with the stainless trim that holds the rubber roof rail trim is mandatory to install headliner properly.
Here's what that looks like.
Hope this helps!!
Cups.
See below.
See below.
Hope this helps!!
Thank you so much. Looks like I don't have any of these. I will start searching the web.
Looks Correct to me. The bows and the 2 rear wire clips for the rear most boe. If the side bow clips are not there you will need them as well.
My bow colors were in this order.
Front
Brown
Green
Blue
Pink
Magenta
Rear
