E Satterfield
Hello. I’m new to Mopars. We ordered a new 408 Blueprint for my wife’s Duster due to not having a local reputable machine shop so I decided to tear down the engine that was in it to basically see if there was anything that I could possibly sell to recover some of the funds for the new engine. It’s a 75 360 block
The heads are 340 X casting but it appears that someone has milled off the rocker pedestals and added these aluminum items for the roller rockers? One of the pedestals has been welded and one was observed broken in half during tear down. Is this a factory modification or done later by someone?
It also has deep dished pistons that look like the could be for a possible boosted application? Seem really dished even for a stock type 8-8.5-1 rebuild?
It’s also running a Comp solid lifter with nearly .500 lift. With the low compression a stock converter 650 double pump Open plenum intake and 2.76 gears I believe I can see why it was such a slug. Thanks for any info.
