jazak5 Well-Known Member Joined Aug 6, 2015 Messages 1,556 Reaction score 873 Location NY Jul 20, 2019 #1 what the best way to block off the heat crossover on the intake of a 340 ?
Mike69cuda Mopar Moron FABO Gold Member Joined Jan 2, 2018 Messages 3,486 Reaction score 3,274 Location Kansas City Jul 20, 2019 #2 Seems like they make special gaskets for that purpose. Google it. If you do that with a stock mechanical choke the choke won’t work anymore.
halifaxhops It's going to get stupid around here! FABO Gold Member Joined Jan 20, 2014 Messages 87,150 Reaction score 67,488 Location Hoppyworld, PA Jul 20, 2019 #3 Gas boiling/ vapor lock
MoparMike1974 FABO Gold Member FABO Gold Member Joined Jun 16, 2017 Messages 4,574 Reaction score 4,372 Location Maryland Jul 20, 2019 #4 We used to jam aluminum foil in them. Worked great and is almost free.
QWKSLVR Well-Known Member Joined Aug 31, 2006 Messages 507 Reaction score 107 Location Shediac N.B. Canada Jul 20, 2019 #5 Fel-Pro makes a gasket with the crossover blocked off. I got mine through NAPA. Bobby
Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member Joined Jan 1, 2018 Messages 5,613 Reaction score 5,190 Location Southwest VA Jul 20, 2019 #6 Fel-Pro Performance Intake Manifold Gasket Sets 1213
jazak5 Well-Known Member Joined Aug 6, 2015 Messages 1,556 Reaction score 873 Location NY Jul 20, 2019 #7 halifaxhops said: Gas boiling/ vapor lock Click to expand... yep nice talking to you @ Carlisle !!!!!!!! next project(S) install rebuilt avs carb with factory intake with a"cool carb" set up and a electronic converted prestolite dizzy
Slantsix64 Well-Known Member Joined May 11, 2014 Messages 3,758 Reaction score 1,746 Location Los Angeles Jul 20, 2019 #8 Ms900411 you need two of them they just leave a little pin hole for some heat, but that's for a 318 small ports. It comes with three gaskets one is almost completely blocked off you need two off the sets to make one set.
