druid318
Active Member
So I ran a search and couldn't quite find what I'm looking for. Maybe I'm searching the wrong terms though.
I am the new owner of a Town Panel, it has a slant six engine, 225 I think. It was rebuilt around 97 or so from the paperwork I have. It has the Super Six intake on it. I was warned that it didnt like to start when it is cold out. I assumed that meant winter, not all the time. My first tank of good gas I got almost 13mpg in town, my second tank averaged 7mpg.
I took a look at the carb, and I know next to nothing about them. The air cleaner wasn't on tight at all, so I fixed that last night by replacing the nut with a wingnut and tightening it down. The one nut on the top is holding the entire air cleaner on, so when that is loosened the thing will just fall off. That doesn't seem right to me.
Anyway. I noticed the air cleaner has second hole coming out the bottom. It has a flapper of some sort inside that doesn't seem to do anything. I also noticed what looked like a pair of mounting holes on the bottom of the air cleaner that has nothing attached to it. Is this smog stuff from a later engine that has been removed or is there supposed to be a down pipe from this to pull warm air when the car is cold? If so where the hell is it supposed to run to? I couldn't find any pictures online that helped.
Also, I have a spare Super Six setup. The entire carb, intake, and exhaust is there in one piece. I noticed there is a spring there that is missing on my the one installed on the truck. It is the spring that is oposite the counter weight for what I beleive is called the Heat Riser. I found a couple of part numbers for springs for the heat riser, but I don't see anything in stock. Is this something that would be available somewhere? I would prefer to not steal the spring off the spare setup if I can avoid it. The hardware store sells springs, but I would hate to put a spring on here that isn't going to work correctly.
Also, is there a difference between Super Six setups, one has what looks like a C at the end of the casting number, the other does not. 4041043 C
