MOPARJ
What can I upgrade now?
I noticed the past few days that my 318 on my duster has been not acting itself. It has an Edelbrock 600, Performer intake, stock fuel pump. The problem only occurs when its warm to hot. What will happen is the idle will come way down and if you give it a hard shot of gas, it will die, cleanly. If it starts again, it may hesitate if you give it gas. If you let it cool down, it is fine again until it gets hot again. I replaced the stock pump with another stock replacement, replaced the filter with a clear unit. That has not helped. The one thing that i noticed yesterday is when cold, the filter is full, but when its hot and starting to act up, the filter is either near empty or sometimes it spits little spurts of fuel into it, but not much, as i f there is an air bubble when hot. It runs great before it gets hot and acts up. Dont know the fuel pressure yet, but i know its not much obviously. The plugs are dry.My hunch is that there is vapor lock, or severe heat soak going on. I just have a standard carb base gasket, not a heat-proof gasket, or a heat shield. I also am thinking about moving the filter after the pump, instead of before the pump. Does this sound like vapor lock too y'all too? The cam eccentric is fine. What gasket or shield should i use? Can i get it at a local parts store? The motor has 83,000 miles and has stock manifolds, if anyone cares or needs to know. Thanks. (Also, it has always been harder to start after it sits for a while when hot, after i put this intake and carb on, which is a biproduct of alluminum i guess).
