heater blower motor
TheMattMobile
74 Dart Swinger
Marysville, WA
Got a 440 in a 73 duster. Want to run the mopar performance valve covers but they don't fit under the blower motor. Was wondering if anybody knew of an aftermarket one that was smaller?
If you don't want to do that or it will not work for you, I know ones out of Neons are small. Should be able to find them at a junk yard. Not hard to take out either. Go under the dash and take out three bolts and it comes ight out.
Don't know if it will work or not and will take some moding to do. Just a thought.
Greatly appreciate the help. We decided we just are going to go without a heater seeing as its always harsher and only driven in nice weather lol
In case you change your mind....heres the solution I came up with. Summit Racing sells there own brand but it's identical to the Flex lite unit.
Much smaller than factory and nothing enters the engine compartment. It's only 9"x9"x6" and uses 5/8" heater hoses for heat for those nights that windows get steamed over
