skep419
5.9 Magnum 4 speed afficionado
I have a 1969 Dodge dart. Need a non a/c heater box. What years will work?
Thanks
Thanks
The emoji wasn't enough67 only controller and cable routing is different. 68 to 72.
I have the opportunity to buy a 1967 heater box assembly with the switch. If I had both it would work? its kinda busted up but anything can be fixed.I have a box with cables if your looking and also a 67 switch
thanks but sounds like I'm look for a 68-72 unit.Mine isn't busted up but the rivets pulled through for the door which is a simple fix.
