heater box questions
Heating / Cooling / AC
  1. Michael Siple
    Michael Siple FABO Gold Member FABO Gold Member
    107
    32
    Sep 23, 2016
    Wilmington, De.
    Local Time:
    2:38 PM
    Can a a/c heater box (vaccuum controlled) accept cable controls from a non a/c dash bezel ?
  2. Garrett Ellison
    Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
    2,357
    1834
    Jan 1, 2018
    Southwest VA
    Local Time:
    2:38 PM
    An aftermarket A/C/ Heater box might, but I don't think your going to make it work too well on the factory box.
  3. Mike69cuda
    Mike69cuda 64 is the new 17 FABO Gold Member
    1,214
    930
    Jan 2, 2018
    Overland Park Kansas
    Local Time:
    1:38 PM
    I take it you don’t want ac in the car? since the ac box is vacuum controlled it would take some figuring out. If you had a non ac box to steal parts from you might make it work. Would probably be a lot easier to just use the ac controls.
    • Like Like x 1
    • Agree Agree x 1
    • Murray
      Murray FABO Gold Member FABO Gold Member
      1,478
      940
      Apr 19, 2010
      San Jose, California
      Local Time:
      11:38 AM
      A/C controls use one cable with vacuum connections. A regular box uses a controller with three cables.
      • Like Like x 1
      • Agree Agree x 1
      • 4spdragtop
        4spdragtop Well-Known Member
        28,435
        8276
        Aug 28, 2009
        Wasting time here
        Local Time:
        1:38 PM
        Good question. I have complete cables but not sure if they are from ac or non ac
      • RedFish
        RedFish Well-Known Member
        23,902
        2602
        Sep 5, 2007
        Local Time:
        1:38 PM
        How/where the vacuum servos mount on box and attach to blend doors will be a lot different from the clips on a box that manual cables attach to. I don't know if robbing parts from a heater only box to build a hybrid would work or not.
      • Mike69cuda
        1,214
        930
        Jan 2, 2018
        Local Time:
        1:38 PM
        I am not sure, but I thought the heater box part was the same and the ac part was added. It has been awhile since I converted mine from heat only to factory ac.
      • Murray
        1,478
        940
        Apr 19, 2010
        Local Time:
        11:38 AM
        I think the firewall is also different. Is your firewall for a A/C car?
      • Mike69cuda
        1,214
        930
        Jan 2, 2018
        Local Time:
        1:38 PM
        The firewall is a lot different. That was my biggest issue converting a non ac car to factory ac. Swapping box types is a lot of work.
      • RedFish
        23,902
        2602
        Sep 5, 2007
        Local Time:
        1:38 PM
        Heat only to a/c box is not so difficult. Some firewall metal to remove. A/c to heat only requires putting metal back again.
      • Michael Siple
        107
        32
        Sep 23, 2016
        Wilmington, De.
        Local Time:
        2:38 PM
        I was thinking if the doors worked with diaphragms to open/close I may be abl
        Kinda the info I'm fishin for.
      • Michael Siple
        107
        32
        Sep 23, 2016
        Wilmington, De.
        Local Time:
        2:38 PM
        All I would ever much care about would be to have defrost on push button side & cold to hot on temp slide. Guess while redoing dash maybe I could just open defrost permanent & keep p/b controls -they will just be there for looks instead of trying to change too much.
      • RedFish
        23,902
        2602
        Sep 5, 2007
        Local Time:
        1:38 PM
        One advantage of the a/c setup is the water control valve. Heat only setup doesn't have one. Hot water circulates in the cabin at all times. You would need to keep the vacuum system, including that water valve, intact and functioning.
