heater core removal
Mikes270dart
Toronto
What do I have to remove, and how to remove, the parts required to get the heater core out. To make things even worse it is a factory air car.
i've got one of these coming up soon...(w/AC)
tell us about it..looks like it didn't take too long...
thxs,
b
The heater box is seperate from the A/C unit so it is quite simple. Undo the two heater hoses under the hood. Remove the liner from the glove box. Inside you will see two cable the have to be undone, two electrical conections a ground wire and some vacuum hoses. On the right side there is a J hook, the nut is on the bottom of the box. On the left side, on the top, there is a bracket you can easily reach, undo that and the assembly is free. All you have to do is remove the unit. You will have to remove the knee knocker to make enough room.
Bimping this.
I know it’s old thread but it was a huge help in replacing mine, yesterday. Thank you Mikes270dart for taking the time to post that. That’s what makes this such a great site...helping each other out.
Bimping this.
I agree thanks for reposting, about to take that on myself!
