72ScampTramp
Scamp Tramp
Ive deleted heat in my scamp. The hole left open from removing the heater box. can i use a driver side fresh air box in its place? Or have have yall done this with race cars?
Josh, you might think about this.
http://www.forabodiesonly.com/mopar/showthread.php?t=39039&highlight=heater+delete
I see what you are talking about. Do you happen to know if the hole on the pass side is the same size as the driver? Not really concerned about looks or door being backwards. Just an effective way of closing off that but still be able to function.
Pauly, I like what you did there mounting the fuse box and ingnition on the inside of the firewall in the center. I'm looking to achieve the same set up. As far as the fresh air box, I plan on making a removable cover with a seal for my car to block it off completely rather then trying to find a heater delete one.
