just need to verify heater hose routing with the OEM vacuum operated water shut off valve.
currently I have from water pump to right side (looking from front of engine) heater fitting.....out the left side , thru the shut off valve with the vacuum port pointed to forward ....then to the intake.
If you have an OEM set up.....confirmation and any pics appreciated.
Thanks,
Denny
Thanks,
Denny
