Heater hose
Snake
Mopar Nut
Belleville Canada
I need to get the 2 heater hoses for my teen 5/8 but how long,want to place them org look.Thanks,74 Duster.
If your going for the original look, they will also need to have the 'Mopar' marking and the part numbers. You can order original looking heater hoses from a bunch of places online and also from your local Chrysler dealer. They should already be the correct length as it depends on if your car has A/C or not.
If your not going for the original look, buy a generic, similar diameter rubber hose and cut them to fit depending on if you want them to run along/on top the valve cover or swing by (and supported by) the passenger fender brace on the later A bodies.
I still have the original heater valve on my 68 and the hose bracket was off a 68 Coronet 318 but routing should be similar. Just ignore the cobbled up A/C hoses for the Denso compressor conversion. Pretty sure I allowed 3 feet per hose and had plenty to work with.
vbpgimage.php
Thats where they reside. Thanks Pishta. The reason I ask is that area is a little cramped and they sit next to the fuel line.
