SB69GTS Well-Known Member Joined Oct 21, 2009 Messages 421 Reaction score 17 Location Ontario Dec 12, 2016 #1 Hey guys ..... Can someone check on a 69 dodge dart how the drivers side vent hose is located on the box. Does it go on the upper or lower opening on the heater box. Thanks Guys
R RedFish Well-Known Member Joined Sep 5, 2007 Messages 25,850 Reaction score 5,351 Dec 13, 2016 #2 Those ports on the heater box are 2 different sizes. The larger port goes to drivers side dash vent so that side gets lions share of defrost.
SB69GTS Well-Known Member Joined Oct 21, 2009 Messages 421 Reaction score 17 Location Ontario Dec 13, 2016 #3 RedFish said: Those ports on the heater box are 2 different sizes. The larger port goes to drivers side dash vent so that side gets lions share of defrost. Click to expand... Thanks ...that helps alot ...back to the build ...next up ...wiring up new gauges
