Hellcat Oil Cooler Fittings
Chuckbizkits
North Orange County, CA
Is there a name/size/type for the fittings on a stock Dodge Hellcat oil cooler? I need to convert to AN.
Looks like you can unscrew those fittings that are screwed into the oil cooler. They are definitely ORB fittings (O-ring Boss) You can take those to a speed shop, or hydraulic shop and have them match the threads. Might be metric threads. Or call the dealer with that part number that's on the oil cooler and ask them...
Here is the OEM part for that fitting on Ebay.
15-19 Dodge Challenger Charger Grand Cherokee 6.2L Engine Oil Cooler Fitting (1) | eBay
That is kind of a neat oil cooler, what are you mounting it on?
I figured it out. -12 O-Ring. Factory cooler. Mounting in fender well.
