Has been rebuilt 1962 single field round back I think.
Below is off the Allpar website.
Round-back alternators all have a build date and part number cast in on a boss just below the “batt” terminal; the part number is a seven-digit part number with a pair of numbers, usually stamped underneath it, showing the two-digit week and the two-digit year. There may be additional numbers whose purpose remains unknown.
The alternator was usually made weeks to months before the car, and usually had date-coded diodes (four digits, the first three for the day, e.g. 225 for the 225th day of the year, the last one for the year), made before assembly of the alternator though not necessarily before the casting. The castings of rebuilt alternators have usually been somewhat damaged by the cleaning process; rebuilt alternators often used machined pulleys, for universal use, rather than the original stamped pulleys. Finally, the rear bearing will usually be flat if it was rebuilt; the original bearings had some raised ridges.
Chrysler used zinc-plated screws until mid-1969, then used both zinc-plated and black phosphate into 1970 before the black phosphate screws dominated; the black screws are reportedly harder to remove and easier to break.
