Help decoding vin, tag and rad saddle
Hyper Henry
Ontario, Canada
Heys Guys
Can someone decode these numbers for me. I get the feeling the fender tag is not correct to the car so maybe the whole front end was changed on it and I could not find a build sheet?? Not that it matters I am building it the way I want so just more for curiosty sake, thanks.
VIN
BH23F8B204533
rad saddle
B8BI99352
vender tag from top to bottom
64 7 1
8 11 16
50 8 1 H6X FF1 B 1
BH23 41 5 27 B15 199352
Whats it supposed to be?? From the top vin its a 68 cuda?? But the bottom vin on the fender tag should be the same. Something on the tag dont look right
Need the letters that the numbers are under on the fender tag to decode it.
On 68 the vin last 6 are not on the fender tag. But the numbers on the core support should match the 6 on the vin tag.Which they do.
ab h u
64 7 1
n rs xy
8 11 16
12345678 AX TRM PNT UBS
50 8 1 H6X FF1 B 1
Car is a 68 Barracuda notch back. But seems like some stuff has been changed on it so I am just trying to decode for curiosty. I am not selling it so just building the way I want to make a nice cruiser.
Thanks
Vin # BH23F8B204533 is Car Line B-Barracuda, Price Class H-High, Body Type 23-2 door hardtop, Engine Displacement F-318, Model Year 8-1968, Assembly Plant B-Hamtramck, and it is the 204533 rd car built on that line. Hope that helps, b. hubs
a6=Bucket seats
b4=Console
h7=Fender mounted turn signals
u1=Sold car (ordered)
n8=Rear Window Defogger
r1=Radio-AM Music Master/economy
s1=Air conditioning w/ heater
x1=Glass-tinted all windows
y6=Black Vinyl Top
H6X=High Trim Grade, Vinyl Bucket Seats. Black Interior.
FF1=Light green metallic
U1=Upper door frame paint black
S1=Horizontal sport stripe black
BH23=Plymouth Barracuda 2 Door Hardtop
41=318cid 2-bbl V8
5=3-Speed Automatic
27=D70x14 White Sidewall
B15=build date November 15
199352=with the B15 date it is the Shipping Order Number: B15199352
The radiator number, B8BI99352, (which is also on the trunk lip), is:
B=Barracuda
8=1968
B=Hamtramck
199352=same as above
What is under AX?
Also, what are the numbers under 1-8?
a6=Bucket seats
b4=Console
y6=Black Vinyl Top
41=318cid 2-bbl V8
5=3-Speed Automatic
B=Barracuda
8=1968
B=Hamtramck
What is under AX?
under AX is 1 and under 23 is 50
Very interesting. I will have to see if i can find the number on the trunk lip. I am wondering now if the dash was replaced and previous owner used the VIN that was in that dash?? I just restored the engine bay and plugged all the extra holes that were for AC but man they were crude so I thought they were added after the fact????
Thanks again
AX= 2.76 Rear Axle Ratio
25= Drip Rail Mouldings
30= Body Belt Mouldings
sounds like a really nice Barracuda !
I never could figure out those Tetris-like '68 and earlier fender tags ...
