Velocity111
I have a 69' Dart that I'm putting on a Wilwood disk brake kit. The 15" rims i currently have will not work, because the center hub diameter is not large enough.
I'd like to replace them with a new set of Mopar Rallye rims in silver. Looking to do 15x7 in the front on 1/2" studs, with 15x8 on the rear with 7/16" studs.
I've only checked with one place (Coker Tire) so far, but the Rallye's they offer only have a hub dia on ~2.8", and I need a min of 3.24" to work with the disk brake kit. Can anyone suggest other places to look for rims? - or even better, I'm sure I'm not the first person to come up against this, and likely there is already a solution for this somewhere. Any suggestions?
worth noting - it has to be a Wilwood kit as I'm using up credit with them for the kit. I would like to do the Rallyes as I just haven't' seen anything else that i really like as much.
Thanks again in advance.....
