HELP! I need a pic
blue missile
Austin Texas
I need a pic of the bottom almost horizontal track on a 73 duster's window glass. I know what goes there just not which end faces the front and which is the top of the track.
Thanks in advance for the help and I WILL document the electric window system install!
Andrew
I believe the back inside part of the regulator track will have a little "bump" or stop. I don't have an actual picture of a 73' Duster, but I've included a generic picture to illustrate what I'm trying to say about the regulator track have the dimple on the left.
Its the window track I need to install in the correct position.
Thanks, mopars deal is upside down from the illustration I believe. But Im not sure.
Andrew
The window track is mounted with the bigger of the two brackets toward the rear. It has two holes in it whereas the front bracket has one.
