Help Identify
kickingpaw
1971 Duster 340
Michigan
Can anyone help me Identify this resistor? Located under dash below radio.
It was warm to touch when I unplugged it. I checked factory service manuel but I
dont see any description.
It is most likely a relay for something like the seatbelt warning or a delay relay for the interior lights.
Go to mymopar.com and download your cars FSM and a schismatic.
Look for a 3 prong plug with the wire colors that were on the plug you disconnected it from. Then trace back to see what it does
I probably should have mentioned its out of 1971 Duster....
I notice the trunk light doent work since I diconnected the relay.
Thank you for the help.
Thanks for the advice,
All the other lights work except trunk, dome, map.
Thanks for your help .
I'll keep searching.
