Help identifying intake
Father in law passed a few years ago and we are finally clearing his house out. He told me he had bought a 6pack intake for a slant 6 when he was in Australia, but I never saw it till now. Can't find much info on it and whether its worth selling or not. Any Info would be appreciated.
Yes, I hereby identify that as an intake. Those other things are exhaust manifolds. I accept Paypal. You're welcome. lol
It was initially done utilizing the rear half & outlet/heat-riser part of the OE manny, the front leg & runners were cut off, and a plate welded over the opening there. This way you could use all of the stock features, equipment, & heat to the intake. Dutra cast the front piece and voila, dual outlets, freer flow & the ability to tune the pipes for best torque/scavenging.
Ok I got it, so you would use the stock rear cut off from the front
Like so
Ok that helps, thanks
Mind You, if You're using an aftermarket intake w/o the heat riser well/pad to mate to & cover that part of the exh. manny, You'll need to fab a cover to bolt/weld on that. I believe Aussiespeed is making the Dutras now, if You wish to add the rear-specific unit to match the frt., as an intake like the Cain wouldn't use the choke well & riser etc.
Dave999,
Your mailbox is full…..tried to send a private message
Peter
