Help inland shifter!!!
bigtimmy78
Member
nebraska
So I dismantled my inland shifter on my 74 duster. Took pictures of how it came apart and camera it was on went down. I know the correct way to "rebuild" an inland shifter is to throw it away but due to budget restrictions I have to work with what I got. So if anyone would have pictures or be able to tell me where how it goes back together I would be greatly appreciative. I think I have it close but not perfect also thinking that it wasn't maybe entirely right in the beginning . It DOES NOT have the t handle cable for reverse lockout you pull up on entire shifter to go to reverse thanks.
It's in pieces again now ready to start over. Big question is where does the thin shim go and how many should there be. Mine had a thick steel one and a real thin like .015 thick one. The thin one was solid with no place for the shifter to pass through to grab the next lever .
