Help me stop
DusterOnaDime
Active Member
minnesota
So in the process of building my duster, I have upgraded my rearend to an 8.8 with disk brakes. I have also upgraded the front to disk using a newer abody setup. My question is…. Do I buy an aftermarket type booster/master cylinder. Or is there another factory one that would bolt right in. Thank you for the info. Ps. The car originally had 4wheel drum
do you have to have power brakes?
because if not, just get this and be done rock and roll.
Choose the 15/16 bore size option (drop-down) for better line pressures.
