So, my setup is as follows:
MP 360/390HP magnum crate engine
cam specs.
288°/292° Advertised Duration
(230°/234° Duration @ .050")
0.501"/0.513" Lift
9.0:1 compression.
4 speed car.
I have an MSD Pro billet ready to run distributor with the two heavy springs and the blue bushing in it to limit the mechanical advacnce to 21 degrees on a slow curve.
I'm also running an MSD 6al box.
The thing that gets me is when I look at the initial timing (no vaccum advance) at idle the engine needs around 32 degrees just to idle, any less and it dies. I'm using an old style light, not a dialback light.
From everything I've read this seems really high. That would put the total timing at 53 degrees. The motor seems to run well, it has a bit of a bog off idle but then comes right into it, it doesnt break down in the higher RPM range, and is not obviously pinging.
Does anyone have any ideas why I need so much initial timing to get this thing to idle?
cam specs.
0.501"/0.513" Lift
9.0:1 compression.
4 speed car.
