mcat
i got my hemi started.(2006 alt) but the the alternator is not charging(i used the below diagram) i took the alt to 2 diff. places both said it is good... i have tried 2 different regulators i tried direct grounds on alt.and reg. the hot comes from the alt directly to the battery, no gauge.i tried all new wires with both regs. when the key is on and one field wire is hot, both wires going into the regulator are hot. if i unplug the both fields from the alt, only the key'd wire is hot any ideas? hi rpm and low rpm.. still no charge i have a small battey/alternator test light with multiple lights that show whats going on. when the battery is checked with it 3 lights are lit.(thats good) when its running, only 1 light lit..(thats bad)http://www.forabodiesonly.com/mopar/attachment.php?attachmentid=1714703694&stc=1&d=1394408896
