No, different case, Bill. The rebuilders modified many roundback 69/ earlier alternators by drilling one more hole, and installing an "aftermarket" brush. The problem with this is, that the original GROUNDED brush mount was still there, and if it accidently got installed, you either had a fried harness or severe overcharge, depending on which terminal the blue field wire was hooked to
Here, modified "roundback"
I'm not sure WHAT this one "is." It has a grounded brush on the left, and a blank position for an insulated brush on the right. It "sorta" looks like the screw hole is factory, but might not be. Maybe this is a late 69/ early 70 casting??
This one is an obvious "rebuilder hack"
You can see the factory insulated brush at 9 o'clock, and the factory grounded brush at 6 o'clock. The horrid hole at12 o'clock was drilled by a rebuilder. The grounded brush would (hopefully) be removed, and a second insulated brush installed in the "horrid hole." AVOID THESE like the plague. During my 15--17 years as a parts pusher, I saw "a few" of these.
Last, we have a drawing of a 70 isolated field "roundback" so before the "squareback" existed. Notice that there IS NO place for a grounded brush at all. In my recollection, this is the only type I ever saw except for the later, "rebuilder hacks"
