help, need to order front end kit
k3522
North East. Pa
I am calling PST to order a front end kit for my mechanic to replace all my bushings. I have large bolt pattern disc brakes, I think from a 1973 Dart.
I dont need any sway bar bushings so my question is should I order the "front end kit" for a 1969 Dart less the stablizer link kit and stablizer
bar bushings? Are ball joints the same for 1969 small bolt pattern and 1973
large bolt pattern?
The upper ball joints are different. Everything else is the same. Order a kit for 73 up or call them and explain what you have. They have surely heard this 100 times. Good luck
PST could not ship until Tuesday. Seem like they did not care. Called trustworthy NAPA.
Mopart.com technical archives is saying lower ball joint is larger but does not mention upper as different?
