HELP NO REVERSE! 65 barracuda
Kickdown adjustment effects the line pressure. It will not make a transmission engage gears in neutral or park. It is straight up a malfunction of the direct clutch, period. If the fluid looks good and doesn't smell burnt, it is a parts malfunction in the direct pack. If the fluid IS burnt, then the direct clutches are fried/welded together. My guess is the bellville spring and snap ring is the culprit.
Hey everyone. Transmission is out. Took a couple days away from it. Today I pulled the torque converter out and the pump is pretty rusty on its face. Maybe I should start a new thread on it but thought of this one first.
Let us know if you do start a new thread. Interested in the results.
just wanted to finish up the thread and say everything was put back together and driving may 12. Had to have a brain tumor removed so I’ll be down for a bit. What’s left: got to redo the fuel system and refurbish the steering coupler and I should have a decent ride. Thanks
