Dartalltheway
I'm trying to pop out the brake cylinder on my brake calipers and it's not work. I've tried air pressure and brake cleaner to loosen it but it won't budge. All help appreciated.
If air pressure fails to move it, connect it back into the brake system and use light hyd. pressure.
Very light application of pedal.
always expand the piston out of the bore with the brake pedal before you remove the line when doing a rebuild
nothing wrong with replacing the seal on a caliper once in a while, if that's all it needs, why replace it, besides I would rather rebuild something than replace it any day,
that way I know it was done to my standard's
p.s. nice tool hemi71x
