Help Please!
johnmucci
moparmucci
Davenport Florida
Ok, I pulled the 7 1/4 rear end out and getting ready to install an 8 3/4.
Where can I find the Main Hard Rubber Brake Hose that goes from the brake line coming from the front of car and goes to the "tee" on the rear end housing? also where can I get the "tee" and the brake lines that go out of the tee to each side of the brake drums?? Thanks!
If you know about what year the rear is, try NAPA that's where I got mine.The tee is on the hose. Make sure you have the vent bolt to install the hose on the diff. The brake lines you can buy at NAPA too, and bend your own, make sure they are double flared when you install them.
right stuff has all the parts also pre bent lines cheap two
just look u right stuff break parts
