Hey folks just double checking something. I've removed the torsion bars, upper and lower control arms etc.. to replace all the bushings. With the upper control arm bushings I've pressed them into the arm, but I also need to press the thrust(?) washers onto the ends of the bushings correct?
I tested the fit without them and it was tight with just the one thrust washer on. Just wanted to double check before I really wreck something. I tried searching but didn't find any good how to's with pictures.
Photo has a single thrust washer on one side. Any tips other than using the bearing press to get both on, I'm assuming this will make them fit better, by pressing them tighter.
Thanks in advance,
Adam
Thanks in advance,
Adam
