Help Removing Shifter Console 65 Cuda
missmopar64
Genoa, IL
My Fellow Moparians
Have run into trouble removing the shifter console from 65 Barracuda automatic.
Cannot get the shifter ball off, is it a press on? Does not seem to be a set screw set up, appears to be square tip, so not threaded end, ANYONE?????
Afaid to yank on it and break it, and can't seem to figure any other option for getting this thing out. All help will be appreciated,
Thanks in advance
Miss Mopar 64
In the front of the black ball is a small hole where an allen screw is hiding. Remove the allen and the ball will slide the top!
Goodluck
Daniel
Thanks to you both for the tech info and the boost back to the top!!!
Very much appreciated
Joy
