Help! SB ARP head stud torque needed!
396 Signet
Pittsburgh, PA
Does anyone have the torque specs for ARP 144-4001? These are the head studs for stock iron heads. Don't have instructions & ARP is closed. Thanks in advance!!
There is no info on the ARP website for specific bolt applications. They have a general table for the various sizes but in my experience the #s they give usually don't match the instructions that come with the parts. Got the value from another site, instructions say 90 ft-lbs with ARP lube. Believe the table said 95.
That sounds close (the 90lbs one). Normally I use the stock spec for heads, which would be 95lbs. But I havent done head studs is a while. Usually I use bolts.
