KindredSpirit
I am converting from single to factory stock style dual exhaust on my 1971 Swinger. It's got a 340 with the stock exhaust manifolds. I bought the complete Accurate Exhaust system from head pipes to tips and I could use help locating the passenger side tailpipe bracket that sits above the axle housing near the rear seat belt bolt. Since my car started life as a six I only have the factory bracket on the driver side. I know the best solution would be to install the pipes and then locate the bracket but I've got the entire drive train out of the car. Could anyone with a factory dual exhaust Swinger or equivalent A-Body post a picture of where the right side bracket is mounted? Thanks in advance.
