GTXperience
Orig Stealth Mod
I have a 340 ('69 casting) that I had built many moons ago. An exhaust lobe flattened out and the motor probably only had two hundred miles on it at best. A friend/acquaintance of mine expressed interest in buying it and I wanted to get some feedback what you folks thought was a fair price. This is only going to be for the short block (along with a pair of rebuildable O-heads) since he doesn't want the W2 setup (which was brand new at the time and also has less than 200 miles on it).
Again, it's a:
340 block ('69 casting) powder painted very close to Chrysler Blue: bored/honed .030 over w/torqueplates & line honed. Tapped for gear drive. Includes: timing chain cover (powder painted blue), water pump & balancer.
TRW 10.5:1 pistons
340 steel crank (turned 10/10)
340 rods recon'd
Clevite bearings
Milodon gear drive
Milodon HV oil pump
340 Windage Tray
Moroso Oil Pan
Since he probably won't want to use the W2 setup, I told him I have a set of virgin (1969/70 2.02 O-heads) to go with the motor. They are complete with rocker assemblies, pushrods, etc. They will need to be gone through. Also included are a set of chrome Direct Connection valve covers and and attaching bolts.
There is no intake manifold included but I do have several rebuildable carbs that I can include.
Also have a new hydraulic Comp Cam ($140) that should work well with this motor for his purposes. I forgot the specs but supposedly is the largest hydraulic cam you can run with a stock HP convertor and 3.23-3.55 gears.
So, what do you guys think would be a fair price? Thanks in advance for any thoughts on this.
Again, it's a:
TRW 10.5:1 pistons
340 rods recon'd
Clevite bearings
Milodon gear drive
Milodon HV oil pump
340 Windage Tray
Moroso Oil Pan
