Help With 69 Dart Rear Glass Installation?
mokid
SW MO
I need some instructions. Does the filler strip have its own adhesive or must one be applied separately? Is a heat gun needed to make it stick? etc.................comments appreciated.............James
Filler strip? The sell windshield sealer in caulking tubes & no heat gun needed.but I highly recommend a hot garage so the rubber is soft. Also put the gasket in first after you caulk the groove of the gasket,then the glass goes in. I used a frosting spreader or bent butter knife w/o any serated edge.
oh,& before putting the glass in,caulk the groove around where the windshield is going in too
