KindredSpirit
Can anyone help with the installation and adjustment of the cable from the dash AC temperature control lever to the blend door lever on the AC/heater box? It's a 1971 Swinger with factory AC. The factory service manual is not making any sense to me - put the water control valve in the full heat position? I thought the water control valve was in the engine compartment. Second question is the "self adjusting clip". Is this a special fastener different from the normal control cable retaining clips?
